Good morning,
I have a question about arrows on ducts.
I would like to put the arrows on my ducts to show the direction of the flow.
I draw some lines but it is not the right way to do it.
How it is possible to solve this?
Thank you.
Solved by iainsavage. Go to Solution.
Solved by HVAC-Novice. Go to Solution.
I use a customised tag which has “text” in it using the Wingdings font which includes arrow symbols.
I assume you want the arrows to automatically change direction based on actual flow? This would make plans more clear. I don't have an idea for that, but that would be cool for pipes and ducts.
I think I know how to do what iansavage suggested, but this seems to be a manual method to decide which way the arrow points (unless i missed the automated part).
Best I came up with is to color return and supply duct differently based on duct system type. This isn't really what you asked about, but works for me seeing better what ducts (and pipes) are what and from that the user can infer the direction.
Attached is a basic one. It contains two types, one for left/down, one for right/up (Revit always rotates the text to be viewed from the bottom or right side of the page).
You need to decide which one to use, it won't automatically detect flow direction (and I don't know of a way to do that).
It should snap to the duct centreline as long as you place it with the leader option switched off.
Wingdings or Wingdings 3 fonts have several arrow style characters and you can see them via the character map app in Windows.
