Arm pivoting around a point
silviobrother
silviobrother
I have a situation and I do not know how to solve it. Please see the attached picture where I put the question and also I explain what do I want to do that arm. Also I attached the rfa file.
Thank you in advance for your support and have a nice day to all.
L.Maas
You have to create the rotation at the center of the shaft.
Create a reference line through that center point and have the eartharm rotate around that point. Use an offset so that it rotates properly.
Attached a quick example.
Some pointers. Normally we set the family as workplane based. I normally would create the eartharm as a nested family. When a little bit more complex models will make life much easier. In the nested family you create the arm and control length etc. In the host family you only control the rotation.
As an example I have added a family with nested arm.Just created quickly, so no proper testing of constraints etc.
Louis
Please mention Revit version, especially when uploading Revit files.
silviobrother
Thank you for the quick answer.
silviobrother
Here is my attachment.
L.Maas
You have to make your nested nested family workplane based (and remove always vertical).
Load it back into your host family
Set the angle of your reference line to 0°.
Select the earth arm family, choose 'Pick a Plane' and choose the reference line.
Now your arm should follow the angle of the rerference line.
Possibly, the family jumped onto the reference line and you have to move the arm upwards (55 mm) so that it is properly positioned.
Louis
L.Maas
deleted, double post
Louis
