Anyone know of any methods for calculating duct fitting areas?
不适用
33,212 次查看
14 条回复
1 条消息(共 15 条)
不适用
Not sure if this is a wish list item or not, and I'd rather not reinvent the wheel on this.
Some of the duct fittings have surface areas calculated, some dont. I'd like to have all the fittings report an area so I can schedule total sheet-metal areas. Anyone here know of an easier way of doing this than going through each fitting family and figuring out how to calculate the areas?
已接受的解答 (1)
33,213 次查看
14 条回复
回复 (14)
2 条消息(共 15 条)
不适用
I asked the same duct area question a while ago, no answers. No information on anywhere. I am still working on getting the duct area easily. What I do is define a shared parameter, and define a formula for that fitting area. A very easy task is turning into a tedious work. Schedule duct and fitting separately, export them, open them in  a spread sheet, delete "m²", sum areas 😞
0 个赞
3 条消息(共 15 条)
不适用
4 条消息(共 15 条)
不适用
Can you not create a family parameter tied into the dimensions etc and the have it show up as an m2 in the schedule?
0 个赞
5 条消息(共 15 条)
Alaaeldin_Alsahli
已接受的解答
the only way is to create you shared parameters
here is a link for how to,
https://chronicle.autodesk.com/main/details/71a731f5-0982-4ade-b79e-f6f09ef6779e
Alaaeldin Alsahli
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
6 条消息(共 15 条)
不适用
Thanks Alaaeldin.
Your solution tied in with the calcs supplies by Moh-azs should work perfectly.
0 个赞
7 条消息(共 15 条)
不适用
See picture below. The calcs for a radius bend worked perfectly and scheduled perfectly. AREA.jpg
0 个赞
8 条消息(共 15 条)
不适用
Simple excel sheets
9 条消息(共 15 条)
不适用
0 个赞
10 条消息(共 15 条)
不适用
11 条消息(共 15 条)
不适用
Hi ALL, I have made a formula that will help us calculate the weights of ducts and fittings based on their area in Revit. I am attaching a PDF explaining the same. Kindly go through and share your comments!.
12 条消息(共 15 条)
不适用
Hi, I am working in the same task at my company, and I would like to know how did you do it, I did not find any PDF attachement.
Luis
0 个赞
13 条消息(共 15 条)
不适用
Luis, I do not know why my previous post did not carry my attachment though I had attached it. I am attaching it with this mail again. I am not able to see it again.!.Kindly let me know how to do it. I have tried using the "Choose File " option under Attachments on both occasions and unluckily it does not seem to work!.
0 个赞
14 条消息(共 15 条)
不适用
i made the calculation sheet (from ashrae) . could have some mistakes, but not bad
my site ://     ,,,,,,,,,,,   ...  linoavac.site.pro
0 个赞
15 条消息(共 15 条)
RobDraw
Thanks for the email blast! 难过表情
Rob
0 个赞
