alignment grid - in view, can't turn off
MuirEng
MuirEng
I have a grid showing up in my view, see image
this is a view, NOT a sheet.
I can't figure out the controls to adjust or turn off this grid. It only shows up in this one view, and others use the same view template.
confused.... please give me a hint.
thanks
Brian Muir, P.Eng, Muir Engineering
HermanSolomon
Hi MuirEng,
If you see the grid in a view instead of a sheet, the most likely suspect in my opinion is that the grid is either a family that is placed in the view, or it might be an imported item.
Can you select the grid at all?
http://revitrecess.blogspot.com/
AJA14
You probably have the show workplane toggle on. Just turn it off. It is on the architecture/structure/systems tab on the right hand side of the toolbar next to the reference planes.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
www.TechRoom.bg
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
MuirEng
perfect, thank!
it seems like I am spending 50% of my time designing and 50% asking "why is it doing this"...
chrisplyler
Been working with Revit for about five years now, and I've got that 50/50 reduced to about 80/20. Smiley Frustrated
