Revit MEP Forum
Additional Flow - Sanitary
4 REPLIES 4
403 Views, 4 Replies
Is there any way to see the additional flow of the Sanitary Systems? I already set the calculations to "Flow only" in the system type properties but can't find it in the properties tab of the Pipe.
Tags (3)
4 REPLIES 4
nmarcelis
Revit Certified Professional Architecture, Structure and MEP.
in reply to: nmarcelis
Yes I already checked it. If I set the system to "Flow only" it doesn't appear in the pipe properties though.
nmarcelis
The problem will probably be located in the used pipe connectors in the families and calculation settings.
No the connectors weren't responsible, the Sanitary systems are working primary with fixture Units.
Forma Design Contest
