Hi there,
The built in revit MEP domestic water flowing parameters works based on Fixture units and flow.
Here in the netherlands we work with Tap eenheden, its basicly the same as fixture units but the values are different.
I made a family off an wallplate (since all our instllations end there) and made a new parameter called TE. then made entered a formula so it projects the flow, see the picture below;
this works, but when i use the system inspector it only projects the flow. I want to project the flow & TE instead of the Flow & FU.
I also want to make the TE flow through te piping system just like the Flow and Fixture units would. but the parameter TE (wich is a shared project parameter) comes up empty. it only projects the value on the wallplates
On the wall plate family:
On the pipe / fittings:
As i said before i want the TE to automaticly add up and let the parameter "flow" throught the system.
Hope someone can help me out.
Thanks in advance!
