Add "Panel Name" Parameter
Is there a way to add the same "Panel Name" parameter that's present on panels and transformers to a custom piece of electrical equipment? It's easy to add a new text instance parameter, but I want to be able to use the same tag on custom-drawn equipment (disconnects, enclosed circuit breakers, automatic transfer switches, etc.) as is used on the preloaded equipment (panels, transformers, etc.).
