Hi All,
I'm working with a linked architectural revit file. I have an area that's a double-height space, where there is a floor covering most of it but and area where you can see below. It would be helpful if you could see what's in the lower floor in areas that are open to below, but when I set the view range below this level, the fixtures are visible (but lighter) that are underneath the floors. You can also see walls and doors.
Is there something I can do to see the fixtures on the first floor that aren't hidden by a floor slab, and only those fixtures? Or is this a consequence of how the underlying architectural link is set up?
Thanks!
you can use Plan Region to display what you need
