Today I opened my project and discovered on 3D view all the graphics looks like wireframe even on hidden or realistic mode. As show on attached images below, the "normal" one, is my old backup of this project. I searched for any solution, but wasn't able to solve.
Solved by robert.klempau. Go to Solution.
Solved by Jacob_United. Go to Solution.
Have you tried deleting the view and making a new one? The graphics can become corrupted for no apparent reason and this will usually fix it.
Let me know how you go.
Hello @vicagxky,
My name is Robert Klempau and like to help you with your problem.
I had the same problem and fixed it with the solution @Jacob_United mentioned.
Deleted 3D view an then create a new one.
Note that if your view had no View Template attached and you had several settings on this view that you want to have in the New view that you create a View Template of this View, create a new 3D view and attach that View Template to it.
Hope that solves it for you.
It worked! Thank's, I just lost all my pipe filters but I can recreate them...
