Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
3d control
7 REPLIES 7
Message 1 of 8
msgoal33
512 Views, 7 Replies
3d control
السلام عليكم
 انا شغال ريفيت على شاشتين شاشه
فيها موديل
(3d)والتانيه فيها
 يتحرك معايا وانا شغال على الموديل(3d)هل ينفع ال
(3d)بمعنى لما اعمل زووم فى الموديل يتعمل فى ال
شكرا
Tags (1)
7 REPLIES 7
Message 2 of 8
iainsavage
in reply to: msgoal33
I tried to translate your post in Google but couldn’t understand the question. Could you please clarify what the question is?
Message 3 of 8
msgoal33
can i control 3d window to move and making zoom on the object while iam working on the model
instead of making many 3d views in each area.
Tags (1)
Message 4 of 8
RobDraw
Look into the selection box. You can select objects in any view, switch to 3D, and then click the tool. Your 3D view will zoom and crop to the objects.
Rob
Message 5 of 8
msgoal33
i meant after selecting the view and when i scroll in the model on an object it is automatically scrolled in 3d view to the same object without making another 3d
Tags (1)
Message 6 of 8
iainsavage
I use the method which @RobDraw described which just re-creates the default 3D view each time.
See screencast https://autode.sk/3ckNGGj
Message 7 of 8
RobDraw
You're not going to get that kind of live reaction in a 3D view. You're going to have to press a button or two.
Rob
Message 8 of 8
iainsavage
in reply to: iainsavage
You can also use ZR (zoom region) to zoom into a portion of the view.
Forma Design Contest
