2 DIFFERENT REVISION CLOUD COLOURS in SAME VIEW or SHEET _ POSSIBLE?
Chitti_Nagaraju1
Chitti_Nagaraju1
Community Visitor
Community Visitor
is 2 DIFFERENT REVISION CLOUD with 2 DIFFERENT COLOURS in SAME VIEW or SHEET is POSSIBLE?
iainsavage
This is one occasion where I think you would need to use Override Graphics in View > By Element.
I generally try to avoid using that except as a last resort but in this case I can't think of another way - maybe someone else has a better solution.
Chitti_Nagaraju1
Community Visitor
Community Visitor
Yeah , that's correct only but still I'm looking for better solution , thanks !!
RSomppi
What is driving this need/desire?
iainsavage
Maybe it could be done with Dynamo or Python but as @RSomppi asked, why do you need this function since the answer to that would determine whether Dynamo/Python could help, e.g. different colours for different revision numbers etc?
Create a selection filter for each set of clouds, add the filters to views, override the filters.
p/s: I swear I read some A(not)I response earlier, but it's gone now.
iainsavage
Yes, there was a post between my last two but they were just trying to promote a product so I assume the moderator has deleted it. My last post now makes no sense so I'll remove it too.
[edit: couldn't edit my post so I've asked the mod to remove it]
