Wall Type Structure - Core Boundaries Visibility Not Showing
Hi.
If you create a wall type with multiple core boundaries as part of its structure, those boundaries only display correctly in views that cut through the wall. Why aren't the boundaries visible in 3D or a plan view when the view range is set to cut above the wall? The top, bottom, and start/end face of the wall should show the core boundaries when the detail level is set to "Fine" for that view.
