La sugerencia automática le ayuda a obtener, de forma rápida, resultados precisos de su búsqueda al sugerirle posibles coincidencias mientras escribe.
Mostrando los resultados de
Mostrar solo
Buscar en lugar de
Quiere decir:
Esta página se tradujo para tu conveniencia mediante un servicio de traducción automática. No es una traducción oficial, y puede contener errores o traducciones imprecisas. Autodesk no garantiza, ni expresa ni implícitamente, la precisión, la confiabilidad ni la exhaustividad de la información traducida por el servicio de traducción automática y no será responsable por los daños o las pérdidas que se produzcan como consecuencia de la confianza depositada en dicho servicio.Traducir
Give the project browser tabs for: views, legends, schedules, sheets,families,groups,links,assemblies. This would greatly reduce the amount of scrolling/collapsing/uncollapsing
With that dropdown, I actually meant a dropdown in the project browser to switch between browser organization options. That way I could quickly change how the views/sheets are sorted. For example: only show views that are assigned to specific phase, are on a sheet, etc...
You can do that already, but it's quite hidden (you have to right click on the header) so a lot of users don't realize it exists. A dropdown would make it much more discoverable (not to mention quicker to switch back and forth between options).
It's a pain to keep scrolling through long lists of items in the Project Browser. My suggestion is to divide and rule, with access to items in the browser dictated by need.
1) Separate Browser windows for Views, Sheets, Schedules, Legends, Families, Groups, Links. That way we have access to whatever we need when we need. This would be OOTB and not customizable
2) Once in the window, we should be able to set up tabs. For instance, in Views and Sheets we set up categories. So if I want to see my Detail category, I should be able to create and access a tab for that. Or I should be able to view my Door families without having to scroll through a gazillion items.
This would allow us to further customize the Project Browser per our workflow and model standards, while enhancing productivity and reducing frustration.
Since this has been dubbed "Future Consideration" (one year ago), do we need to repost it (like for "Archived" ideas) to get Autodesk to consider it again?
No, there is no need to post the idea again. We will reconsider projects in the "Future Consideration" state as we adjust our roadmap. We will typically not reconsider things that are archived, although I'm sure there will be exceptions.
Bro, This important thing is not in their future road map. They are working on something much more important things for our benefits. So, chill, do not fret. Have 'faith' in Autodesk and get used to the current UI.
What more important things? I am curious, but once received a survey asking whether we wanted the cancel buttons left or rather in the center... That didn’t help the faith in what’s important for them...
@sakar_deepak did you not just say "Bro, This important thing is not in their future road map. They are working on something much more important things for our benefits. So, chill, do not fret. Have 'faith' in Autodesk and get used to the current UI."
@sakar_deepak I was also curious about what it is that you consider to be "much more important"... but then you're curious, too? Huh?
@peter_vanorshoven You can get hints by looking at the accepted ideas here as well as the current roadmap, but (due to the NDA) if you want to know specifically (and even try it out yourself - no install required), sign up for the beta program (beta.autodesk.com) and give your input on the new features (to make sure they're done right the FIRST time)!
@sakar_deepak LOL. Never underestimate the potential for miscommunication. You sounded so serious, I didn't know what to make of it... That, and I immediately thought of one major UI improvement, so I thought you were referring to that.
Improving Revit browser is much needed and was already suggested here and received much support. I would like to be more specific. I suggest adding another level of editing to the browser that allows the creation of tabs for the main titles and any other sub-families as needed. The idea is to avoid the tedious scrolling down and up in the current browser. Do not decide which are the tabs that are necessary to all of us. Let us custom decide about our needs.
In some projects the Project Browser is very extensive. A good idea to optimize the query of projects views and list of families would be to have an additional tab for each of the items.
