Show Pinned files in Revit Home
Add some functionality to Revit Home in the 2019.1 release to show pinned files.
10 Comments
Like in AutoCad, there should be an option where the user can pin recently used files on the opening page when loading the program and it being there every time they use it.
The opening screen of Revit used to be semi-useful. In particular recent projects worked and it was handy to pin projects so that they didn't drift off.
Current version of Revit (2019.2)  made that page pretty much redundant. Recent models don't actually show recent models, at least not for me. All other shortcuts/conveniences are gone. And everything is HUGE.
Either make that page serve some purpose or just get rid of it. Why do we have to put up with these unwanted and insignificant "features" when there are still so many basic features missing from Revit: keynote editor, ability to align tags and other text objects, useful legends, ability to annotate locked 3D views, the list goes on.
dplumb_BWBR
Sorry, but I feel almost the opposite.
We've had the Recent Files screen disabled for over 10 years.
It was WAY too dangerous & easy to accidentally open a Central file or an out of date Local.
With 2019.2, we've finally turned it back on.
I do agree with you about the ability to pin projects, though.
Also, some people have found that if you open a Template file (.rte), the Home screen stops updating.
You have to delete all the Recent Files from your INI file.
THAT definitely needs to be fixed.
TimGrissom
I would love to see this option as well as allowing users to remove recent files that they don't want showing up on the Recent Files screen.
In general, the ability to add, remove, and pin files.  Maybe even the ability to rename the shortcuts so if you have a project that has a really long name for some reason you could change the display name to be something more simplified.
robert.jungergard
I would like the option to pin recent projects at the Revit home view.
I know you can pin projects by the "file -> open" and it would be great to implent that same option to the start menu.
Tags (4)
vitormsantunes
Please, allow users to Pin/Unpin files in the Models and Families, in the Recent files Window, like AutoCad already have!
Thank you!!!
ks2_wmb
Sharing the "pin" setting between contexts would be great.
Ric_Weber
@kimberly_fuhrman-jones I found another that needs marked as implemented I think.  As @dplumb_BWBR pointed out, the home screen recent files has now been updated to work better and the template file issue has been resolved.  The idea to have the ability to pin files from the home screen is in https://forums.autodesk.com/t5/revit-ideas/pin-projects-at-the-revit-start-menu/idi-p/10813808 idea and has several votes already.
Status changed to: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
To follow the progress of features in development, please see the Revit Public Roadmap and join the Revit Preview Release to participate in feature testing. (Note that Accepted Ideas may not be immediately available.)
We are pleased to say that this has been implemented in Revit 2024.2! Thank you for your contribution to improving Revit!
 -The Factory
