Shaft openings: symbolic line - bug
Not really a new function, rather an improvement/bug.
When changing the symbolic lines in a shaft opening to a different line style, the previous one reappears when you finish the sketch.
If you delete and redraw the symbolic lines, it works just fine. But ofcourse this takes up way more time than just changing the line style.
2 Comments
JensDeSmedt
The best thing what you can do is contact technical support. They will contact you whitin 2 business days and try to find a work around.
The bug will get lost here and they will never notice. Last week I reported bugs which seems to exist for many years. There are no problems if nobody complains...
https://knowledge.autodesk.com/contact-support
DGarcia_GCAArch
Revit 2022: still not working.
The only way I found is to delete the lines and draw it again....
