Section Box control
Section Box control
Small Projects leads to small Section Box(es). Large projects leads to Section Boxes which are not easy hard to control, especially the control handles with lots of geometry. What if some extra handles were available?
1 Comment
dplumb_BWBR
Are you using the latest version?
Revit 2018.2 had some improvements in the Section Box grips.
Not what you're asking for, but the grips are noticeably easier to select
Personally, I'd like to see an (additional?) set of grips at the corners of the box instead of the center of the faces.
Not only would they be easier to find, but you could adjust 3 faces at once instead of three separate operations.
