Show only
Search instead for
Submitted byAnonymouson11-14-201601:48 AM
Status:
Archived
Same spacing in hosted rebars as in Area Reinforcement
It would be better if the hosted rebars in a Area Reinforcement got the same spacing as set in the properies of the Area system. See attached picture, where the area system has got spacing 300mm and the hosted rebar got 291,8mm.
The problem you have with that is area reinforcement your placing multiple bars at once. You may wish to have different spaces for each one. So you can't have it like the rebar bar spaceings.
I think you misunderstand. The bars that is actually hosted by the area reinforcement get different spacing than the spacing set in the area system. If you set layout rule to maximum spacing you want the bars to show the maximum spacing in tags (e.g. 300 mm) and not the actual spacing (e.g. 291,8 mm). When you remove an area system the actual spacing is set for the rebar sets.
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
