Revit Coordination Alert Window Show Command
I would like Revit to do the following:
When you use the Coordination Alert window, after selecting the coordination object (i.e. wall change), you can RIGHT CLICK and choose SHOW.  This will make Revit display a view or cycle thru different views so you can see the objects that need coordination resolution.
3 Comments
corkybenle1
PLEASE DISREGARD....THIS FEATURE ALREADY EXISTS.
Ric_Weber
@kimberly_fuhrman-jones, just ran across this post.  Per the OP's own comment, this is already available.  I assume a status change is in order?
