This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Problem with Spot Elevations on Ducts
When I try to use spot elevation on a linked file with 2 ducts above each other, the bottom elevation is taken from the lowest duct, even if you tag the top duct.
I did talk with Autodesk, and it look like it is a bug.
Hope it will be fixed, in an update.
