When tagging a Part, the original object properties should be available for a tag label. Example: A structural column has a “Column Location Mark”. This property is not visible in the properties of the Part made from that object. Parts do report some original properties, like Material as read-only. All original object properties need to be available.
- Show all Original object properties as read-only
- Allow all these properties as well as the Part properties to be used in tags. The user may want the Column Location Mark from the original object, but the volume from the Part
Parts allow hosting of structural reinforcement (see Revit Help ). If Parts are used as appears to be intended for construction detailing, all properties from the original object should be available.
