Multi-select Rows for Filters tab in visiblity/Graphics
It sure would be great if I could select Multiple rows at the same time in the Filters tab.  Often times when working in a work-share model there can be many types of systems that I may want to edit at one time.
I am in Plumbing Systems designer.  I do not want to see all the process pipes.  My current work flow is that I have to add filters then turn them off.  I would love to be able to select them 1X and then check the Visibility off.
1 Comment
lionel.kai
Implementation of the "OR" in filter rules idea (which is already "Accepted") should help you with this, as you could (hopefully) just make ONE Filter to control...
May I suggest that you join the Beta program and make sure that they implement the idea in a way that would help your situation? They're probably still looking for use cases, so you should submit yours. 🙂
That said, could you just use a Filter with <Contains> "Process" to catch all of them, instead of the individual ones that you show?
Forma Design Contest
