Move any dimension text like in Autocad
I need to move some dimension text and i just can't. In Autocad you can move the text of any dimension, just right-click and move it with/without leader, reset text position, etc. In Revit some dimension texts can move, but others are stuck in place, even when their position doesn't seem to fit the right way.
We need the option to move any dimension text with / without leader, even when it fits right, because sometimes it may overlap with other tags, or other text, or whatever other graphical objects may be in vicinity.
3 Comments
dplumb_BWBR
What's preventing you from moving the text?
Every Dimension should have grips when selected that allow you to move the text and/or add a leader
You don't right-click, you left-click the dimension line
ipselute
@dplumb_BWBR : I really don't know what's the problem. Underneath my dimension text there is a detail items (breakline family). And clicking on the dimension selects the breakline instead. I hide the breakline and i moved the dimension outside the drawing. The text is just stuck. For the second dimension in the row i can move the text, but for the first one i have no luck.
The black fill represents a section view through a concrete slab and a concrete beam. The beam height is very large, so i made a break in the section view to not see the entire height of the beam. In other case i have similar section but with a concrete wall instead of concrete beam. The dimension of wall height is stuck as well. Just like the dimension of the beam height.
My guess is that the section break for the beam (or for the wall) is somehow interfering with the dimension.
@ipselute  Interesting...have you posted this on the Revit Structure Forum to see if there is a solution?
