Modify tools should not exit out of the current drawing tools!
When I want to offset, trim, mirror, scale or move geometry, Revit always exists out of my drawing tool (for walls, Detail lines, Model lines, etc.). This makes it very annoying to work with Revit, because I am required to input redundant commands. Why should I want to exit from any of the aforementioned drawing tools when I want to make modifications? I don't! So Revit shouldn't force this upon its users.
This is one of the most time inefficient methods there is. If I used anything but a line drawing tool (e.g. fillet arc) I first need to reactivate the drawing tool I used and then the type of line/ curve I want to create. That's two commands for every modification command I used!
