Measurement Tool Fix Request
Using Revit 2027, I took a measurement using the Measure tool, my typical next step is to highlight the result in the "Total Length" dialog in the Top Tab Bar. Only to find it is now basically grayed out and read-only, cannot highlight and Ctl+C > Ctl+V the result into any other tool dialog, like Move or Copy, like i have been doing with Revit since inception .. can this be reverted or revived?
I doublechecked the Measure functionality in Revit 2026, that's how it worked in the previous version.
Very hopeful this is an easy and swift fix.
Cheers,
Ryan
3 Comments
icecreme98
Yes, came across this the other day which is annoying.  In their rush to remove the Option bar they've not provided the ability to use the features in it.  Same for sizing pipe sizes that is no longer possible for multiple pipes anymore.
Status changed to: Accepted
Our teams are looking into this 'glitch'. Thank you for bringing this to our attention!
treyk
Thanks for reporting this!  I've assigned it to our developers as issue REVIT-252484.
