Copy with Base Point
Title says it - copy / cut and paste with base point. No more additional positioning needed afterwards.
18 Comments
young
Is this a function that is not fulfilled by the out of the box paste functions?
Simon_Weel
@Anonymous: I should have mentioned copy / cut and paste to / from clipboard.
tony.crawford
If you use the "Paste Aligned..." options in the Copy - Paste tools, you should get the same thing as the Copy with Base Point tool in ACAD.
There are options for "Paste Aligned to Selected Levels", "Paste Aligned to Selected Views", "Paste Aligned to Current View", and "Paste Aligned to Picked View."
Try the Paste Aligned to Current View tool first. This will paste you object to the same X-Y coordinates as it was copied from.
Is that was you are looking for?
Simon_Weel
@Anonymous: these paste-options won't let you paste objects to a particular spot right away.
Chonghyuk.Lee
I will be happy if you implement the features like Copy with base point (source point / Object snap) and Paste with base point (second point / Object snap).
I submit this idea on behalf of one of our valuable customers, Mr.Sudhan.
Magnus.B
The copy command "CO" in Revit works just as copy with Base Point. you cant type coordinates in Revit but snap to different points works fine.
schlueter
But then your not able to copy it in another view. This works just for the current view.
Magnus.B
True, the copy command doesn't work between levels and that would be a desired function.
SamuelAB
Have you tried with the Paste Aligned function? This is a basic functionality that most users are not aware of.
Chonghyuk.Lee
Here is an update from customer and see the below.
Copy with basepoint in Clipboard & paste with basepoint in Clipboard. Must copy to clipboard & paste from clipboard.
It is useful from one revit file to other.  One location to other location. Easy to rebar. Easy unique dimensions.
MatthewBradley
The current copy and paste function with the options for pasting do not suit copying between models.
i.e I have similar flat layouts which have different locations in my main model so the copy aligned will not work.
If I want to paste a selection of items into various models (that are in different positions) there is no easy way to do this other than paste from clipboard and them manually move it into position. If the items to be paste are hosted then they will not paste in the middle of no ware.
I would like to copy from a point and then paste from a point into another model.
Currently you cannot do this.
This appears to be an easy fix so please can you look into it.
avis_ambalathil
Can group the elements needed to be copied. Then change the group origin to the desired location (e.g project base point) by dragging the group origin. Then select paste to another file using copy from clipboard then the cursor will be at the base point of the copied elements (group origin) then pick the desired base point in the required file to get the elements pasted. But it will be great, if we can get the option of copy with base point like CAD.
 CopyCopyPastePaste
Evalucia
It should be as easy as : select objet, right clic : copy with base point, clic the base point. Go to the other view, paste the objet directly where you need it in only 1 clic and it's done.
But we have to transform it into a group (just to be able to have a base point) or paste it "somewhere" and then select it to place it where we want it. And that is if we can snap somewhere helpfull on the objet. If not, we need to place it in a few steps. Or draw lines to be able to snap to the right place and delete the lines after.
honewell
How has this not been implemented!!!
ANTE.SLISKO
It is not clear to me how someone figured that using Internal origin as basepoint is a good idea. Please give us the option to copy at lease based on survey or PBP.
honewell
Bump.
This still should be included in basic functionality. there are so many times that i'm copying from one section to another or one plan region to another where the ootb functions in revit just don't work effeciently.
jordanlatta
Bump. This is still a problem when copying anything from one model and pasting into another model. I'm sick of pasting off in the distance and then having to move everything, which sometimes is quite broken if even a single electrical outlet has lost association with its host wall.
payingtoomuch
Generally, when I paste an item into another model or view or whatever, revit shows the location that I actually want it to end up. However, for whatever reason revit wants me to click somewhere else to insert it and then I have to select it and move it to wherever it was/ create a group etc before I move it so I can select a specific point.
Why would it be that it shows up correctly and I cannot just hit enter or something and have it stick to the location where revit placed it initially without any manipulation from me?
Blue hi-light at bottom is where revit auto places before clicking anywhere..... it's on the level like it is supposed to be.
Blue hi-light at the top is where it will be placed if I click.
Why can't I just hit enter and have it be placed at the lower location where it already is?
Does this make sense?
