API access to Room openings geometry and materials in Revit
Currently, there is no easy way to access the geometry of a room with its openings. It would be very helpful to have one.
26 Comments
cmungenast
Yes, please.
ALso open up the properties of geometry in curtain panel families so dynamo/addins can look for transparent panes. Very often there is a mix of several different materials in curtain panel families, and currently this valuable modeling technique makes it vary hard to calculate WWR and daylighting.
I also strongly support this.
YarUnderoaker
I guess this idea is intersect with Real Fnish Materials on Rooms Schedules
If we get room as real geometry object with ability to define a layered structure of surfaces (wall, floor, ceil finishing, skipboard and etc.) then we can get configure and automate this process by API.
May be room must be placed between core wall or room separators and then coated with insulation and finishing.
Status changed to: Gathering Support
We are updating this thread to Gathering Support. We are continuing to evaluate where this request falls into our roadmap and will provide an update when we have made a decision.
The Factory
r.godin
has the subject been resolved since then? because I have been looking for the solution for several months. Thank you
omarselim4YDX7
