Access Nested Wall Properties from Stacked Wall Dialog
I often get frustrated when I select a wall, click on Edit Type, and find that it is a stacked wall so then I have to note the family name and go searching for it in the project browser.  I would like there to be a way to access the type properties of nested wall families from within the type properties dialog of the stacked wall.
Here is how I see it working:
  1. User selects stacked wall family and clicks Edit Type
  2. User clicks Edit Structure button to see the nested wall types
  3. Each nested wall family has a button or doodad of some sort that acts as a shortcut to open the type properties of that nested wall. OR Add an Edit Type button down with the Variable, Insert, Delete, Up, and Down buttons so the user can highlight the wall they want to edit and then click the Edit Type button below.
Forma Design Contest
