access Line Weights (settings) from Dynamo and/or Revit API
I'm starting to get my feet wet in Dynamo, and looking into using it to compare and/or enforce standards. Starting from the basics, I want to make sure that the Line Weights match... but what? I can't just pull out a bunch of lists?
17 Comments
eric.anastas
I've asked for this in the past. There is an existing feature request CF-3772
sasha.crotty
Status changed to: Archived
lionel.kai
Even though it's "archived", I just got another vote on this one, for some reason.
@sasha.crotty Since (according to eric.anastas, above) this already has a change request number (CF-3772), does that mean it should be "Future Consideration" (instead of "Archived")? Or do I really need to resubmit?
sasha.crotty
I'll make it easier, I'll un-archive. Since this is API this shouldn't have been archived with 7 votes. Not sure how that happened.
sasha.crotty
Status changed to: Gathering Support
lionel.kai
Thanks, Sasha!
helengorina7713
This is a very important feature.
Files with very different lineweights are graphically incompatible. It is a necessary diagnostic tool when we think about re-using drafting views (details) which may come from different sources.
If we are able to get and set these values, it would make it possible to re-map and reuse old content without so much pain
thanks
any news on accessing Line Weights in Dynamo ?
cheers
Any  news? It would be interesting we could access Line Weights and Line Styles from one file and transfer them to another using dynamo without having to open source file.
maisoui
up!
Any News On This?
Up, this is still very needed!
Sterling_Bradby
Observer
I'm managing our standard details that come from a wide range of places and would love to be able to access the line weight of a line, especially in Dynamo. Any thoughts on this?
jeremy_tammik
jeremy_tammik
parley.burnettMZ2ZR
Any updates on this? Needed!!
eric.anastas
@parley.burnettMZ2ZR
I've brought this up in the Revit API round table session at AU the last 2 or 3 times I've attended. 🤷🏼‍:male_sign:
The best work arounds I can think of is to replace the Line Widths from a known correct file with transfer project standards.
Or read/write the values through the actual line widths UI using System.Windows.Automation.
