Unable to make changes in Revit cloud model
343183MadsF
Message 1 of 9
343183MadsF
Hey.
I have an issue specifically on my laptop, where i am unable to make any changes to my groups shared Revit file. I can open the file, and save it locally, but when i make changes in the project i always get the same error message:
I've tried updating all the apps, resetting my laptop, using another account with the same access, checking my own accounts access to the project is correct and clearing the cache and pac cache.
Follow up: I tried using Revit 2024, where it seems i have no issue with accessing a Revit Cloud Model. So the issue is with my laptop in regards to Revit 2025.
Here are my specs in case anything stands out:
Thinkpad T14 Gen 1
Processor: AMD Ryzen 5 PRO 4650U with Radeon Graphics 2.10 GHz
Graphics: AMD Radeon (TM) Graphics
RAM: 32 GB
64-bit operatingsystem
Windows 11 version 24H2
Replies (8)
Message 2 of 9
RSomppi
Can you please explain this in more detail?
Message 3 of 9
343183MadsF
I am able to open the Revit Cloud Model i share with my group, and see the latest changes and load the latest changes. I am also able to save a local copy of the project, but any changes i were to make in the local version, will not affect the actual project.
Message 4 of 9
RSomppi
Revit does this automatically for you. I don't understand why you are doing this. Please explain the actual steps that you are taking from open to save.
Message 5 of 9
343183MadsF
I open the project, i try to change something, like moving a wall, and i get the error.
Message 6 of 9
RSomppi
If you're not going to answer the questions, it's going to be difficult to figure out what going wrong.
Message 7 of 9
343183MadsF
You're not focusing on the problem, you are focusing on saving a local file, which is not related to the shared cloud model that i am trying to interract with.
Message 8 of 9
RSomppi
You brought it up and it raised a flag for me because it didn't sound like a correct workflow. I don't see anything else that would indicate a problem with workflow but you have not described how you are opening it, which I asked.
Good luck.
Message 9 of 9
misc0006
Community Visitor
Community Visitor
I have the same problem - did you find a solution of the problem?
