Revit ADSK Unsigned Add-in Warning
eschappe_flad_com
eschappe_flad_com
This morning several of our users in Revit 2021 and 2022 are reporting warnings about an unsigned add-in from Autodesk related to BIM360. Nothing new was installed and we deduced this was caused by Autodesk's maintenance over the weekend.  1) Anyone else seeing this?  2) can someone from Autodesk chime in as to why we are being forced to accept an unsigned add-in in order to use BIM360 all of a sudden?
colinSRA
Several people in our office also noticed this.
We're seeing popups with names like:
   “SkyscraperClientHostApplication”
   “CollaborateDB”
   “Views for A360”
It would be nice if add-ins published by Autodesk could be verified by Autodesk's software...
apjones
See https://forums.autodesk.com/t5/bim-360-support/the-publisher-of-this-add-in-could-not-be-verified-re...
Pete
>Please Accept as Solution and give Kudos as appropriate to further enhance these forums. Thank you!
sasha.crotty
Hi all,
Unfortunately there was a certificate that expired that's causing this issue. It's safe to load the add-ins. We're looking at resolution options.
Apologies for inconvenience caused.
Sasha
Sasha Crotty
Director, AEC Design Data
