Detached Model
Detached Model
Detached Model
Good day,
One of our users are trying to open a central model on A360.  Whenever she opens this particular model the sync icon is greyed out and the file name has changed to a long series of numbers.
Do you perhaps have any suggestions or resolutions for this issue.
Your assistance will be greatly appreciated.
Telushia.
lars-ake.johansson
Looks like the locally cached version of the C4R model have lost it's link to the cloud model.
I can't say at this point why, it might be so add-on you are using that are causing this to happen.....
A quick workaround to the issue would be to delete this model form the local collaboration cache and reopen it (this will recreate the local copy of the model):
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Regards
Lars-Ake Johansson
Sr. SQA Engineer
same issue, here is a link to our post (not yet solved 2:35pm 3-31-2017)
https://forums.autodesk.com/t5/revit-collaboration-forum/c4r-automatically-detaching-file-upon-openi...
Solution / Solved!
at least for us...
1. - Go to the location below and delete all files in the folder.
2. - Restart the machine
3. - Open the model via BIM360
C:\Users\YOURNAME\AppData\Local\Autodesk\Revit\Autodesk Revit 20??\CollaborationCache
Lars-Ake Johansson
Sr. SQA Engineer
