- Mute
- Permalink
- Report
I am evaluating Revit over a Drive Mapping tool for a customer. After I collaborate and create a central copy in a folder in the drive mapping tool, when I synchronize with Central it works a few times..and then it fails. In the journal I see an entry (the whole journal is attached)
' 5:< SLOG $b78c786e 2017-03-22 19:19:36.905 .STC:RL:LockRoot RW SCODE=0x80004005
' 6:< SLOG $b78c786e 2017-03-22 19:19:36.915 .STC:RL:Error "Unspecified error "
'C 22-Mar-2017 19:19:36.925; 6:< Save exception "COleException", code=0x80004005: Unspecified error
'C 22-Mar-2017 19:19:36.925; 6:< COleServerDoc::ReportSaveLoadException
' 6:< TaskDialog "Failed to open document."
'CommonButtons : Close
'DefaultButton : Close
'H 22-Mar-2017 19:19:39.029; 6:<
Jrn.Data "TaskDialogResult" _
, "Failed to open document.", _
"Close", "IDCLOSE"
Whenever I see this error, I usually notice that there is a file in revit_temp folder . Not sure if it is related (The file in this case is called pulse-b78c786e.tmp and seems locked by revit)
I don't know whether this is a problem with the drive mapping tool or revit. If you can please give more details on what the failure is and what file or operation is failing, I could take it up with the drive mapping tool to see if they can solve the issue.
