Cannot modify shared coordinates on Cloud (ACC) models
Ian_Shafer
Ian_Shafer
This is a failure in Revit and the Autodesk Construction Cloud!
It is not uncommon for adjustments to become necessary to the location/elevation of a building(s) with respect to real world coordinates.  This GAP in the system forces me to have to:
  • stop all work and
  • download the source files to my local
  • to make the necessary adjustments to the shared coordinates then
  • republish all the models, then
  • open each model and reset all the link paths in each linked file.
This is not saving me time; it is costing all my consultants money.
Please correct this failure in Autodesk's system as soon as possible.
If anyone has a simpler solution to address this issue, please respond to the post.
Ian
(apologies for being blunt)
(apologies if I missed any earlier posts regarding this issue)
Use Acquire Coordinates, not Publish Coordinates.
Ian_Shafer
Please elaborate ...
Do I move the building model in the site then open the building and acquire?  Or the other way around.  I have tried this but my Acquire option is not available.
Link the Site in the Building > Move it to align with the Building > Acquire Coordinates.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Revit-C...
Ian_Shafer
Thanks again for your quick reply ...
However as you can see, I get no option to "Acquire".
I have managed to address the issue but I had to stop Sharing the coordinates and used Manage/Relocate Project instead.  It gets me where I need to be but without shared coordinates.
I'd still like to find the correct workflow but we can at least get by for now.
Ian
Ian
Manage > Coordinates > Reset Shared Coordinates
Click the link and Acquire.
Ian_Shafer
I appreciate your persistent assistance.  This appears to have worked.
thank you
