Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Cannot modify shared coordinates on Cloud (ACC) models
6 REPLIES 6
Ian_Shafer
365 Views, 6 Replies
This is a failure in Revit and the Autodesk Construction Cloud!
It is not uncommon for adjustments to become necessary to the location/elevation of a building(s) with respect to real world coordinates.  This GAP in the system forces me to have to:
  • stop all work and
  • download the source files to my local
  • to make the necessary adjustments to the shared coordinates then
  • republish all the models, then
  • open each model and reset all the link paths in each linked file.
This is not saving me time; it is costing all my consultants money.
Please correct this failure in Autodesk's system as soon as possible.
If anyone has a simpler solution to address this issue, please respond to the post.
Ian
(apologies for being blunt)
(apologies if I missed any earlier posts regarding this issue)
6 REPLIES 6
in reply to: Ian_Shafer
Use Acquire Coordinates, not Publish Coordinates.
Ian_Shafer
in reply to: ToanDN
Please elaborate ...
Do I move the building model in the site then open the building and acquire?  Or the other way around.  I have tried this but my Acquire option is not available.
Link the Site in the Building > Move it to align with the Building > Acquire Coordinates.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Revit-C...
Ian_Shafer
in reply to: ToanDN
Thanks again for your quick reply ...
However as you can see, I get no option to "Acquire".
I have managed to address the issue but I had to stop Sharing the coordinates and used Manage/Relocate Project instead.  It gets me where I need to be but without shared coordinates.
I'd still like to find the correct workflow but we can at least get by for now.
Ian
Ian
Manage > Coordinates > Reset Shared Coordinates
Click the link and Acquire.
Ian_Shafer
I appreciate your persistent assistance.  This appears to have worked.
thank you
Technology Administrators
