Can't obtain permission to edit the element: The Central Model is inaccessible. You can check out worksets at risk, but consider carefully!
WSP-Rigel
WSP-Rigel
Is there a solution to this yet? cant seem to find one, one of the BIM modelers is getting this warning it just seems to go away on it on but pops up once in a while hard to pin point what it is ive asked them to Expand >> but thought i try asking first.
ChitnisPrateek
Hi @WSP-Rigel please check out this article
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Revit-Can-t-obtain...
If this works for you, please mark it as a solution. Thank you.
Thank you.
Prateek Chitnis
BIM Manager | AECO (Buildings)
Did you find this post helpful? Feel free to click on the Like button.
sureshchotrani
Kindly share the journal file to troubleshoot, details on the journal file can be found at
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Location-of-journa...
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
