This has me baffle :-
Laptop1 (work) : I have 2 shared models I link to. One of these models I get an error message "It looks like requested service is currently unavailable" so it won't load this particular model. The 2nd model links (from the same shared folder location) just fine.
Laptop2 (home) : both models link just fine.
Both lap tops I run under my own Revit & BIM collab accounts.
I've cleared the cache on Laptop 1 as per these instruction https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Clear-a-corrupt-da...
but no difference after it rebuilt the cache.
I haven't yet tried the 2nd suggestion of copy the cache from one PC to another.
I figured if a fresh new cache didn't work copying one probably wouldn't work either (I'll give it a try though when home).
Is there any other likely causes &/or fixes?
thanks for any help.
Trev.
