A360 Sign-in Error
A360 Sign-in Error
Message 1 of 15
A360 Sign-in Error
When i try to login to the A360 online account i keep receiving the same error message.
I know i am not signed in anywhere else. When the project manager sends an invite to my email to join a particular job we are working on, i click it and can access the project through the browser. However, when i open up Revit 2016 and go to the A360 tab, it states i am not part of any project. Please help!
Replies (14)
Message 2 of 15
BrettWright
Hi Ben,
Sorry for the trouble you're having here.
I'm not a Revit expert so i'll move this over into the Revit forum as well to get their opinion, however, what i'm wondering is if there is any way to do a cache clear, and/or browser history clear, so that your Account ID credentials aren't cached in the location where you're logging into from Revit?
The other thing i'll have you give a quick shot would be to change  your Account ID password by going to accounts.autodesk.com and logging into the security settings area to do a quick Password change. (that might work as well)
Then after you change the password, do a test logout and login from within A360 via autodesk360.com and then from Within Revit to see if that works.
Let us know if this helps or not.
Brett Wright
Message 3 of 15
Swathi_Vadlamani
Ben,
I belive you are trying to login to your hub from login.autodesk360.com and since your default A360 Hub has been deleted, you are seeing the above error. I will send out an email to you on how to access your Team hub successfully.
Swathi Vadlamani
Autodesk 360 Web
Message 4 of 15
Hi there,
I keep getting this screen when i logged in to my account, i tried to create a new account, but same thing kept on happening. whats going on?
Message 5 of 15
Swathi_Vadlamani
Can you please try accessing myhub.autodesk360.com/g/landing and see if A360 portal loads for you? Looking forward in hearing from you.
Swathi Vadlamani
Autodesk 360 Web
Message 6 of 15
paul
Hello, I am having the same type of problem - can you help me?
Message 7 of 15
Swathi_Vadlamani
Paul,
Can you please let us the the hub you are accesisng and the error you are seeing? Please do attach a screenshot.
Swathi Vadlamani
Autodesk 360 Web
Message 8 of 15
paul
Please see the error attached, and get back to me ASAP. Please understand
the every minute counts...
Paul Waldner|Conceptual Design - Development
TaraCon Precast | Hawley, MN 56549
Office: (218) 216 8260 ext.437 | E-mail:
paul@taraconprecast.com
Message 9 of 15
Bud_Schroeder_ADESK
Hi Paul,
It does not look like the error image was attached, can you try attaching it again.
Thanks in advance for doing this.
Bud Schroeder
AutoCAD Customer Council Beta Programs
Autodesk Inc.
Join the AutoCAD Customer Council Beta Program.
Message 10 of 15
paul
PLease let me know if the snip uploaded correctly.
Message 11 of 15
Bud_Schroeder_ADESK
Hi Paul,
You may need to sign in to share it. If that fails please eMAIL it directly to me at first.last@autodesk.com, just swap out first.last with my first and last name.
Thanks in advance for getting us these details.
Bud Schroeder
Autodesk Inc.
Message 12 of 15
paul
Bud - your e-mail does not work - please shoot one directly to my inbox on my first name @taraconprecast.com
Message 13 of 15
Bud_Schroeder_ADESK
Thanks Paul and just sent you an eMAIL.
Bud Schroeder
Autodesk Inc.
Message 14 of 15
paul
Hello, Do you have a different e-mail i can use i seems that i can not send to any Autodesk.com account. I do not know why....
Message 15 of 15
paul
Hello, I just shot you an e-mail using a different account. Please let me know once you receive and i resend the snip.
