Zooming in 3D Cuts Through Near Objects
mcovill
Message 1 of 14
mcovill
On my model, when I try to zoom in up close to the model, the model gets cut - in the same way it does at the back if far clip is active.  It's like the picture plane is several feet/meters in front of the camera. Viewing the selected 3D camera in plan view shows that it is not even close to the walls getting cut... see below.
Any ideas on where the settings are that can fix this?
Mike
View of corner is being cutView of corner is being cutbut, the camera is not even close to the cornerbut, the camera is not even close to the corner
Replies (13)
Message 2 of 14
RDAOU
Message 3 of 14
Cool.  Been using the Full Navigation Wheel?  My guess is that it's related to Increase/Decrease Focal Length.  FWIW.
Message 4 of 14
mcovill
I was.  I've changed the focal length in and out and it doesn't seem to fix the problem.  I suspect it's also related to the Crop View and Crop View Visible.  I've been playing around with different combinations of those as well.  No luck.  Is there any way to reset the 3D view back to factory crop and focal length?
Mike
Message 5 of 14
Can't you just recreate the FUBAR View?
Message 6 of 14
Mike
Just create a new camera view.
Message 7 of 14
mcovill
It's the default 3D view. I've closed it and re-opened it from the menu bar. It keeps its settings apparently.
Message 8 of 14
Delete it and create another.
....I thought you said it was a Camera View?
...if you delete the default 3D View, a new one will be created when you press the camera icon on the QAT.
Message 9 of 14
mcovill
Well, that worked.  I didn't know you could delete the default view.  🤔
I've also been trying to understand the whole zooming and focal length system. It would be nice to be able to set up a 35 or 50 mm image or some other focal length, ... to match it to real photos for instance.  But, thanks.  Moving along...
Mike
Message 10 of 14
Camera views default to 50 mm focal length.  You can change to other specific lengths such as 35 or 28 by changing the view crop size proportionally.
Message 11 of 14
jjbaena
Greetings,
Do you know how can I do same thing in Navisworks?. I am having the same issue.
Thanks for your help!
Message 12 of 14
Sleepingfish_Kuo
There is no way to edit Crop.Max.Z in UI.
You can try Dynamo or Api tools to edit it.
...Or ask who changed it and let them change it back.
Message 13 of 14
awarhurstM9KVB
Community Visitor
Community Visitor
Reduce the far clip offset  - seems counter-intuitive but often this makes it easier to see things up close
Message 14 of 14
jordan_craddockDSUXY
Community Visitor
Community Visitor
Legend!
