Hi everyone,
I have a problem with the calculation of Room perimeter. I have curtain walls and columns in my template.
When I connect the curtain walls and place a room the perimeter is correct as you can see.
If I place a column with axes 200x200, when I place a room the perimeter is correct.
If I place a column with axes 100x100, when I place a room the perimeter is NOT correct.
How can I resolve it? I think this is so important bug of Revit. If someone have the solution please help me.
Solved by RDAOU. Go to Solution.
Seems like rounding? Check the value if you set units to 3 decimals? Perimeter, my bad... could you share the file?
Sorry but I can't because the template contais sensible information about the office where I work. Do you need the model or can you try to found a solution without it?
It is an issue with bounding element which has a section smaller than 140x140mm.they tend to act weird...Even with just room separators.
You can work around that by making the two walls non-bounding and adding a room separator instead and drag slide the separator at 1 side just enough to be 140mm from the opposite bounding edge...
I already try this solution, turn off room boundaries from curtain walls and from columns and place room separator. I think this is an importat limit of Revit because I have to spent a lot of time for place room separator. A programm such as Revit mustn't have this limitation.
Thanks for your time.
This is a user forum, people here can only help you workaround certain things... otherwise, you shouldn't waste your time and other's 🙂
