I am an MEP designer but am drawing a rough floor plan for a project I am doing. I have created a single stairway. Two story building. From the second floor the stairs only show as coming up from the bottom. Is there a way to show them going down? I have attached the views.
Gelöst! Gehe zur Lösung
Gelöst von shpakkala. Gehe zur Lösung
Tab through to select the up Text. Edit type-->duplicate create new for down arrow--> Change start symbol type to arrow and arrowhead type to anything else--> okay in instance properties of up text change text to down.
Thank you. It was actually a dumb question now that I figured it out. The direction was set to fixed direction instead of automatic direction. Thanks!
