Is there anyway to make new/edited textures show up across all users in worksharing. Currently if I edit the central model, the changes stay on my end and I am able to see textures I have changed since I have the original texture images on my machine. But when teammates use the model they see blank walls/floors. Do we all need to share the texture image and set it up on everyone's own machine? Or is there a way to sync them easier?
If textures are custom and they are brought in from your local machine then only YOU will be able to see them. If they are on a network drive, then every team member who has that drive mapped should see them. If you are in BIM360 then this is an entirely different story.
Check out this link for BIM360
