Worksets set as uneditable can be edit
tw_you
tw_you
Other workers can still modify it even though it says no in the editable column of the workset. Do I need to add workers to the owner so that other workers can't modify that workset? Also, can I think that the non-editable setting of these worksets is similar to the laylck setting of CAD? I'm still a beginner at REVIT , so I have a lot of difficulties.  PLEASE help me...
jay_colc
If it has not been checked out by another user it can be borrowed by another user who want to edit it so basically!
  • Editable means only you can modify the element no one else can edit them.
  • Non-editable means no one has them and anyone can edit them.
Jay Colcombe
Autodesk Certified Instructor
tw_you
thank you so much!!!
Autodesk choose to name Workset statuses very poorly.  Editable and non-editable are not meant for the editing availability of the worksets content, but for renaming or deleting the worksets themselves.
- Noneditable: anyone can edit the content of the workset.  This should named Content Editable.
- Editable: only the one owning the workset (by set the workset to editable) can edit the workset content.  This should named Content Editable by [username] Only.
tw_you
Agreed. I'm even using the Korean version, so I think it's more confusing because the settings are listed as words that have translated English into Korean. Thank you!
