How can I move section line from one floorplan view to another?
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
ConstantineC
890 Aufrufe, 5 Antworten
Hello. Is it possible to move the section line (symbol) from one floorplan to another? Why is the Reference other view greyed out? Is that suppose to be the way?
I tried with copy-paste aligned to selected level. Something is copying but its not visible.
5 ANTWORTEN 5
Nachricht 2 von 6
blank...
als Antwort auf: ConstantineC
Section is a 3D object, you don't move it to another floor plan, if it's not visible it means it doesn't reach that level. Open the section, turn on its crop region and stretch it so it encompasses the floor plan where it's not visible.
Nachricht 3 von 6
ConstantineC
als Antwort auf: blank...
The section view cuts through every level. I have also checked the hidden elements, there is no section view hidden.
Nachricht 4 von 6
jay_colcombe
It it related to a Phase/Workset or a Filter?
Are the Discipline Options different between the Plan and Section?
Also please check
In the Properties Palette, locate the parameter “hide at scales coarser than”.
Jay Colcombe
Autodesk Certified Instructor
Nachricht 5 von 6
ConstantineC
I just created a new section and before placing it, I choose Reference other view, but it still just showing on a single floorplan.
I have choose Reveal hidden elements, selected everything and checked the Filter and there is no section view selected.
Nachricht 6 von 6
ConstantineC
als Antwort auf: jay_colcombe
Yes,  that worked!  I think it was both hidden in   views and  the "Hide at scales coarser than"
After I changed the scales, i managed to find it hidden
Thanks!
