Worksets and Facebased Furniture problem
M_Perez
Message 1 of 21
M_Perez
I have a model with a lot of Face-based Furniture (Chairs, tables...) I have found out that when I change them to another Workset they disappear in any view (3D, floors...) but they still exist and are counting in Schedules. If I select them (from a schedule) and change them to the original Workset, they will be still not visible.
I can solve the problem selecting a new face and placing the furniture again in the same place.
Anyone has suffered a similar problem?
Replies (20)
Message 2 of 21
Schedules ignore worksets, other views don't. That is how it is. What you do is not set the workset to Hide by Default universally, or turn the workset to Show for each view.
Message 3 of 21
M_Perez
I know it, and of course was the first thing I checked. As I said, they won't be visible again even if i set the workset back to the original. That discards for me any Workset-Visibility related error.
I am actually pretty sure it is a bug, and would like to prove or discard it.
Message 4 of 21
M_Perez
@Viveka_CD , could you report it?
Message 5 of 21
RobDraw
Maybe before it gets reported, you could share this family for others to look at before you try to report it as a bug. Maybe there is something else going on that you are missing.
Rob
Message 6 of 21
M_Perez
They were several families and we had the same problem in 3 Computers, working on the same central model. I noticed that some families weren't having the problem and that is how I investigated that just the ones Facebased were the problem. After that we proceeded as I said, we clicked on select a new host an placed the again at the same place.
I agree it would be good to check it again and I wish I knew how to reproduce the problem...
Message 7 of 21
Viveka_CD
Hi @M_Perez
Can you share the families? Let me know and I can send a private upload link.
Message 8 of 21
RobDraw
You have a problem that can't be reproduced? Doesn't sound like it warrants wasting any more time on it.
Good luck.
Rob
Message 9 of 21
M_Perez
@Viveka_CDI've looked for a copy of the model where the problem still presents is. If I copy the elements in a new project, it is also solved. So I cleaned the model to make it lighter.
I'll be glad to share it with you. Waiting your link :)
@RobDrawI hope nobody has to fight against it, but if so, I already posted how to work around the problem, and I am doing my best to get the reason founded. For me it is important to solve errors that compromise the model in a way that can produce discrepancies.
Message 10 of 21
Viveka_CD
Hi @M_Perez
Thanks for making the model lighter. I have shared the private folder with you.
Please let me know if you have trouble accessing.
Message 11 of 21
RobDraw
You have a problem that cannot be duplicated. Why are you wasting other people's time, if you can't make it happen again?
Rob
Message 12 of 21
Viveka_CD
Hi @M_Perez
Please turn on visible in all views for the furniture workset - see below and let me know if this helps resolve your issue:
Message 13 of 21
M_Perez
@Viveka_CDI'm sorry, but that produce no difference. That problem persists after that. Don't you have the same problem with my file? Did it work for you?
Message 14 of 21
Viveka_CD
Hi @M_Perez
Yes, it works if you turn on the visibility of the workset in the view you want the furniture to appear.
Please see this article for more information.
Also, see Workset visibility
Let me know if this resolves your issue.
Please select the Accept as Solution button if my post solves your issue or answers your question. Likes welcome!
Message 15 of 21
RobDraw
It's funny how the vast majority of these posts that claim to have found something wrong with Revit turn out to be OIE.
Rob
Message 16 of 21
M_Perez
I had no time to answer before, sorry for the delay.
I have installed screencast and recorded it in case I am missing something. It is still not working for me. Any Ideas?
Message 17 of 21
RobDraw
No one can do anything but guess without an example of the problem. At this point Viveka is the only one who has seen this and she stated that it is a workflow issue.
Rob
Message 18 of 21
M_Perez
Sorry, I did not paste the link to screencast https://autode.sk/2mrR7kk
You are right, I didn't know were to upload it, here ist the link to the rvt file: https://autode.sk/2L4CrXf
But, I have to say that as I was looking at my video again I notice that the elements are not disappearing but "just" flying away!! Looking at the video you can see the blue temporal measures. The furniture is landig a few meters out of the visible area. I am now not less confused as at the beginning...
Message 19 of 21
Viveka_CD
Hi @M_Perez
Let me take a closer look and let you know for an update. Thanks for sharing your screencast!
Message 20 of 21
Viveka_CD
Hi @M_Perez
This is a visibility issue as mentioned before, can you please try the recommendations in the above posts and let me know if this works for you?
You are welcome to continue the conversation and unmark the solution if you'd prefer.
