Working with door families - missing parts
alexis_cherner
Message 1 of 17
alexis_cherner
hello! this might be a basic question but I'm new to editing families in Revit. If I click on a door with a panel attached to it in the model, and edit the family, why does the panel not show? how might the  family be constructed that I can edit it? see images below:
(within model, panel is showing)
within family editor, panel is not showing
Replies (16)
Message 2 of 17
Switch to a different type in the family.
Might want to close the door family and edit it again from the project to make sure you have the correct family.
Message 3 of 17
Maybe you broke it. Not kidding.  What do you do after you clicked on "Edit Family"?
Message 4 of 17
alexis_cherner
Edit family takes me directly into the family and it just looks like this..no sign of the sidelite. If I close it out, evverything looks fine in the model. Was happening to my colleague as well.
Message 5 of 17
Sounds like a Detail Level thing.  Have you looked at Coarse, Medium and Fine representations? You can change via the geometry's Visibility Settings if you want.
Message 6 of 17
...or it could be a shared, nested condition and you TAB-Selected on the nested one in the Project and hit Edit Family.
Message 7 of 17
alexis_cherner
I did try course, medium and fine as well..would there be somethign else in visibility settings? Thanks!
Message 8 of 17
alexis_cherner
oh interesting, let me try this
Message 9 of 17
shir_rustici
so the door could be a nested family that is shared into the main family. Can you select the entire panel and edit it? When you selected the door did you need to tab to select just the door? Families can be created and then loaded (also known as nested) into other families as shared which allows you to also tab, select the nested family within the Revit model.
Shir Rustici
Message 10 of 17
alexis_cherner
this worked!! thanks!
Message 11 of 17
You can always post the file here for us to examine and tell you exactly - instead of guess. 😉
Message 12 of 17
alexis_cherner
this worked!
Message 13 of 17
@alexis_cherner wrote:
this worked!
What worked?
Message 14 of 17
alexis_cherner
Tab select, I was editing the wrong family. Thank you!
Message 15 of 17
alexis_cherner
haha true -- company file. next time I would edit and make a new file if possible!
Message 16 of 17
So, I guessed correctly. TAB-Selecting was the culprit.  Exactly what I told you above.
Message 17 of 17
Oh, I see. @shir_rustici also mentioned it moments later. I guess great minds think alike.  😉
