Wooden Man Parametric
aRcHiTeCt.JM
Mentor Mentor
Message 1 of 9
aRcHiTeCt.JM
I would like to know how to make this Wooden Man Parametric.
It's a family I have created for some rendering pouposes.
any assistance will be appreciated..... 🙂
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Replies (8)
Message 2 of 9
http://planta1.com/blog/rotating-a-revit-model-family-in-3-different-axes-by-reference-lines/
...use above reference to model body parts as nested families inside the host humanoid assembly.
Message 3 of 9
...or model body parts and host to adaptive point that can be pulled in multiple directions with another adaptive point connected via a Ref. Line (like a marionette string).
...full disclosure: I'm not a puppeteer by trade.  Just theorizing how it might be modeled in Revit .
Message 4 of 9
aRcHiTeCt.JM
... nah ... forget it !!
... I will not be waisting that amount of time for something that I can edit in less than 3 seconds to get to the ideal position...
Smiley Happy
aRcHiTeCt.JM
REVIT EXPERT ELITE
Message 5 of 9
3 Seconds!!! Who are you; Barry Allen?!
Message 6 of 9
Wow! You're on fire today, @aRcHiTeCt.JM!  Smiley LOL
Message 7 of 9
aRcHiTeCt.JM
... on fire !!!
Smiley LOL
aRcHiTeCt.JM
REVIT EXPERT ELITE
Message 8 of 9
Actually, @aRcHiTeCt.JM, I don't want a solution credit for that post of mine. It's unhelpful to the community.  Either take it away, or mark my  post where I linked you to  http://planta1.com/blog/rotating-a-revit-model-family-in-3-different-axes-by-reference-lines/ as an accepted contribution.  I believe that one would be most beneficial to others who read this thread.
Message 9 of 9
This really is a non-trivial task and Revit is not the right platform for this. I really believe that the amount of effort you'll put into this is not worth the perceived benefits. In particular you will end up with a huge list of parameters that won't make it any easier to position the puppet because you won't be able to visualise their outcome in your head easily.
For example, take a look at the number of degrees of freedom in upper limb. That's 7 parameters just for one arm. This sort of armature thing is typically implemented using an Inverse Kinematics system, which Revit doesn't support because it's not relevant. Good luck!
