Just trying to get my witness lines to work properly.
From a brand new default architecture template, nothing else in model, I draw a 8" basic rectangle wall.
Then change the witness lines to the exterior wall, enter a new value in the temp blue box, and I get the error message, "Can't change dimension segment to this value".
I want to enter an exterior value, my witness lines are always on the interior, so I click till the temp dim is exterior and I get the error message.
Help
What dimension are you trying to change? If you only have one element in the project and that element is a wall, then the temporary dimensions would only reference the wall length when the wall was selected.
I had the very same frustrating issue. Hitting the Num Lock or Clear key fixed it for me. Good luck
Hi - Are there solutions to this? (Error message when trying to move a wall using temp dimension at face of walls.)
I've tried several but no luck yet.
I have the EXACT same problem! Learning through Linked In & can't mimic his drawing due to this error. Simple task using temporary dimensions & it doesn't work!
Hi - upgrading to 2019.2 did the job. But also, I started a newer thread with the same question and the last to answers from “TDoan” (similar - spelling may be wrong here) also work without the upgrade. Good luck!
