wood framing extension for revit 2018
rclement
Message 1 of 10
rclement
have been looking for this extension for revit 2018 without much success
Replies (9)
Message 2 of 10
MostafaElashmawy
the wood framing extension is part of Revit® Extensions for Autodesk® Revit® 2018 which can be found at your subscription downloads.
a direct link is below
https://up.autodesk.com/2018/REVIT/REX_2018_Win_64bit_dlm2.sfx.exe
Mostafa Elashmawy
Message 3 of 10
rclement
Cool thank you for some reasons I couldn't find it
Message 4 of 10
I am looking for an extension for wood framing. Where can i find a similar add-on but to revit 2019?
Message 5 of 10
did you get an answer? I'm looking for the same thing. I've found MWF Pro wood but it's too indepth. I Know there ws REX but not exist on 2019
Message 6 of 10
rclement
yes I did ill give it to ya later I have to look in my past forum questions.
Message 7 of 10
rclement
if you look at some of the replies you will find the link .says 2018 but I don't know if it will work in say 2020 I know it did in 2019
Message 8 of 10
Here you can check agacad`s wood framing software, which is revit`s extension:
http://www.aga-cad.com/products/bim-solutions/wood-framing-professional-suite
Message 9 of 10
rclement
does it now work with revit 2020 or 2021?
Message 10 of 10
rmeenhuis
Yes, AgaCAD Woodframing Tools are also available for Revit 2020 2021 and 2022. See the website for more information:
Wood framing BIM & 3D modeling software for prefabricated timber frame system design in Revit® – BIM...
