Wood Column Hatch in Plan
7 REPLIES 7
Message 1 of 8
1352 Views, 7 Replies
I've been using the attached timber column family from the Revit library (first time using it). In my model I'm assigning it a wood material that has one hatch for surface pattern and a different hatch for cut pattern. But in plan/RCP where the plan view cuts through the column I see the surface pattern.
I tried cutting a vertical section directly through the column and noticed that the cut pattern is working there. Does
Revit not recognize plan cuts as horizontally-oriented sections? Is there a way to get this column hatch to read as sectioned through without doing a bunch of annotative regions?
7 REPLIES 7
Message 2 of 8
I'm not sure what you are seeing, but your Column displays Surface and Cut Patterns correctly for me.
...I wondering if the post I deleted might actually have been on point.  Pre-Cut vs. Not Pre-Cut  Behavior?
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Still, I can't seem to replicate what you are describing. I tried on 2019.2.
Message 3 of 8
Try the revised one attached below.
Message 4 of 8
in reply to: ToanDN
@ToanDN : Are you getting the same behavior the OP is describing?
Message 5 of 8
in reply to: barthbradley
No.
Message 6 of 8
@Anonymous : View Visibility/Graphic Override. Final answer.  Smiley Wink
Message 7 of 8
Yep that was the problem, someone did graphic overrides in view. I thought I checked that when I was going through the problem the first time but I obviously missed something. Thanks for the help!
Message 8 of 8
in reply to: ToanDN
Thanks for the family mods @ToanDN - it will come in handy for this and other models!
Forma Design Contest
Technology Administrators
