won't let wall finish show up on plane
ShineThrone
Message 1 of 8
ShineThrone
I won't let wall finish show up on the plane, I tried, but not work, Revit 2021.
Replies (7)
Message 3 of 8
Create parts and filter parts using materials.
Message 4 of 8
ShineThrone
But parts will show the lineBut parts will show the lineI don't know how to hide Finish 2 [5] onlyI don't know how to hide Finish 2 [5] onlyI want section have Finish 2 [5] but plan not showI want section have Finish 2 [5] but plan not show2021-08-11_22h13_25.png
Message 5 of 8
syman2000
I am trying to understand what you trying to achieve. Do you want the exterior finish wall layer to turn off while retain other wall components? I would agree with @ToanDN to use parts and hide those wall layers. If you cannot stand those lines, I would simply use the miter and then use LW (linework) tools to hide those lines.
With parts, you can change the material easily by adding comments or go by material of the assembly.
Message 6 of 8
You can Merge parts.
Message 7 of 8
Maybe the OP is referring to this:
...or maybe this:
Message 8 of 8
ShineThrone
Ok, thanks!!
